Mytek Brooklyn dac
Mytek Brooklyn dac
Berichtdoor Leeuwarden » vr 20 okt 2017, 9:07
Brooklyn is in nieuwstaat en wordt geleverd in de oorspronkelijke doos.
Kleur: zwart
Vraagprijs € 1600,- ex verzending.
SPECIFICATIONS :
CONVERSION: up to 384k, 32bit PCM, native DSD
up to DSD256, DXD, 130dB Dynamic Range
MQA HI-RES DECODER: built in certified hardwareMQA (tm) decoder
DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless, all formats),
AES/EBU (PCM up to 192k, up to DSD64 DOP),
2x S/PDIF (PCM up to 192k, up to DSD64 DOP),
Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP),
SDIF3 DSD up to DSD256
CLOCK: Mytek Femtoclock Generator (tm) 0.82ps internal jitter, Wordclock Input
and Output (allows stacking multiple units for multichannel operation, includes mch DSD)
ANALOG OUTPUTS: RCA, balanced XLR, simultaneous, 50 Ohm impedance
HEADPHONE OUTPUTS: Reference High Current, High transient Headphone Amp, 500mA,
6 Watts, dual headphone jacks, designed to drive hard to drive headphones.
BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
1dB step digital 32 bit attenuator and purist relay bypass.
BUILT-IN ANALOG PREAMP: Line level input or Phono M/M, M/C input, relay controlled.
AUDIO INTERFACE FUNCTION: All digital inputs can be routed into computer via USB2. Allows connection
of external digital sources such as CD Players and digitizing ADCs.
REMOTE: Included, universal remote capable
FIRMWARE: Upgradable via USB Control panel
WORLDWIDE POWER SUPPLY
OPTIONAL DC/BATTERY POWER INPUT: 12VDC
DIMENSIONS: wxdxh=216x216x44mm
WEIGHT: 3lbs, 1.5kg
"Ik heb het nog nooit gedaan, dus ik denk dat ik het kan!" ***Pippi Langkous***
Re: Mytek Brooklyn dac
Berichtdoor Leeuwarden » ma 23 okt 2017, 16:49
Verkocht.
Terug naar “Archief”
