R2R volume regeling aangeboden.
audiofreak10
Berichtdoor audiofreak10 » zo 07 jan 2018, 21:16
Beschrijving
Aangeboden wegens overcompleet een super gebalanceerde volume regeling van Vicol audio type Maya.
Vollidig te bedienen met ab of via een blue tooth app.
1 maal gebruikt om te testen, maar wegens ander project overbodig.
Looking for state of the art volume controller for your product ?
You are on the right place.
Maya is a 64 step R-2R ladder volume controller designed as your ultimate solution in input selection and attenuation.
This attenuator provides 64 positions ranging from 0 to -63dB with average stepsizes of 1dB.
Mute at >130dB. Left and Right channels completely isolated with separate grounds, ideal for dual mono approach.
Input resistance ranges from 16.37k up to Rload . Where Rload = your pre/amplifier input impedance.
Constant output resistance 10K.
IN - OUT complete passive R-2R resistive network with zero active parts, make from this attenuator an ideal solution when it comes to no compromise audiophile equipment. The high-quality Zettler relays and Melf resistors provide superb audio quality which is maintained over a very long lifetime.
Features:
 - R-2R 64 1dB step attenuation
 - Android client for bluetooth remote control - BluThor apk
 - infrared remote RC5 protocol with autolearning
 - infrared remote NEC protocol for Apple remote (default)
 - OLED display
 - 4 selectable inputs
 - independent volume control for each input - very good for A-B source comparison
- extra low noise ground separation between digital and analog circuitry
 - inrush current protection
 - soft start with speaker protection
 - soft turn off with speaker protection
 - plate voltage delay for tube pre/amplifiers
 - temperature display and monitoring
 - temperature protection
 - serial I2C bus for unlimited channel extension
 - easy direct control and setup with precision optical encoder
Zie de site van Vicol voor meer informatie.
Inclusief Philips ab.
Nieuwprijs op dit moment incl. blue tooth module is €395,-, ik heb er nog €459,- voor betaald.
Vraagprijs is €250,- excl. eventuele verzendkosten, nu verlaagd naar €200.
En weer een verlaging naar €175,-
Laatst gewijzigd door audiofreak10 op zo 28 jan 2018, 16:54, 5 keer totaal gewijzigd.
Re: R2R volume regeling aangeboden.
Berichtdoor dre » zo 07 jan 2018, 21:18
Is deze gebalanceerd?
потому что он может!
audiofreak10
Berichtdoor audiofreak10 » zo 07 jan 2018, 21:21
Ja, dit is de gebalanceerde uitvoering.
audiofreak10
Berichtdoor audiofreak10 » vr 19 jan 2018, 23:02
Up en prijs aangepast.
audiofreak10
Berichtdoor audiofreak10 » zo 28 jan 2018, 16:55
Up en weer de prijs aangepast voor deze bijzonder goede volume regeling.
audiofreak10
Berichtdoor audiofreak10 » za 03 feb 2018, 20:55
En is verkocht
Terug naar “Archief”
Gebruikers op dit forum: CCBot, Google [Bot] en 0 gasten
